Afternoon everyone. As I continue to plug away at my suspension build, I've run into a bit of a snag. I purchased a set of ARP 100-7719 Miata studs to run in my Rio hubs/Aspire rear brakes. In prepping to take my drums to a machine shop to have the holes drilled to the proper size to allow the studs to be pressed in, I decided I'd press out the stock Rio studs from the front hubs and install the ARP's while I was at it, however, the stock Rio studs have a bigger base than the ARP's, meaning the hole is now too big to install the new studs. Where did I go wrong? Is there any problem with having another set of holes drilled in the front hubs to allow installation of the new studs?
Thanks for reading!
Thanks for reading!
