14x7
  • 14x7
    Looking at cheap rims and the steel circle track stuff always comes to mind. Found a set in 14x7 with a 4 inch back space.
    Will this work ?
    I dont mind stretching/rolling fenders, but i seem to recall issues with the rear strut saying hello to the rim on some cars.
    CURRENT. Past
    88 festiva L. 89 xr4ti
    14 foST. 89 xr4ti
    82 F100. 97 silverado
    82 GS1000. 06 h3
    82 GS750. 79 ta 6.6
    74 TC185. 89 turbo katana 600
    69 T500. 80 gs1000
    15 sonic 82 cr480r
    So it has a +25 mm offset?
    That would possibly fit, but 7" is a hard fit with stock suspension
    Will Samet
    How to find me:
    Feel free to PM me anytime!
    Instagram/Twitter: @WILLSAMET
      ill be doing some sort of coil over. ima assuming ill need camber in the rear?
      im not sure on offset in metric terms, just has listed as 4in back spacing
      CURRENT. Past
      14 foST. 89 xr4ti
      82 GS1000. 06 h3
      82 GS750. 79 ta 6.6
      69 T500. 80 gs1000
      15 sonic 82 cr480r
        If you are going with coilovers, the Advanced Suspension setup is pretty much the only way to go. I believe a 14x7 +25 will fit with that setup, but I would ask Charlie (Advancedynamix) to be sure.
        And I would also suggest getting a set of Camber spacers to go with your wheels no matter what, as it really helps the performance overall.
        Will Samet
        How to find me:
          theyre bassett 47ST4S
          CURRENT. Past
          14 foST. 89 xr4ti
          82 GS1000. 06 h3
          82 GS750. 79 ta 6.6
          69 T500. 80 gs1000
          15 sonic 82 cr480r
            awesome, thanks
            CURRENT. Past
            14 foST. 89 xr4ti
            82 GS1000. 06 h3
            82 GS750. 79 ta 6.6
            69 T500. 80 gs1000
            15 sonic 82 cr480r
              I ordered a set of circle track hoops for a Chevy truck project once... they weren't even close to round. I doubt a set would work on a Festiva without a ton of wheel shake.
              '88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
                They did mention Off road Use only on the website, along with the fact that it can't be balanced on a conventional machine...
                John makes an excellent point, Festivas are very sensitive to out-of-round wheels.
                What draws you to the D hole steelies in particular over a different wheel choice?
                Will Samet
                How to find me:
                  A few reasons, ive always liked the d window, my grandpas f100 had them.
                  Theyre cheap
                  Come in multiple sizes and offsets
                  I could see that for sure because theyre so light, which makes me wonder do you remember what brand you bought? My cusin ran Bassetts on his chevelle crew cab with no out of round problems so I'd probably only get them as thats what i have experienced in person
                  CURRENT. Past
                  14 foST. 89 xr4ti
                  82 GS1000. 06 h3
                  82 GS750. 79 ta 6.6
                  69 T500. 80 gs1000
                  15 sonic 82 cr480r
                    Also, a lot of the wheels that I end up liking are only available in fifteens or larger. The more I look at cars with fifteen's on them the less I like them. They look good with a little bit of tire on them
                    CURRENT. Past
                    14 foST. 89 xr4ti
                    82 GS1000. 06 h3
                    82 GS750. 79 ta 6.6
                    69 T500. 80 gs1000
                    15 sonic 82 cr480r
                      Well I can't say that I don't like all festivas the have fifteen's because they're definitely some that I really do like
                      CURRENT. Past
                      14 foST. 89 xr4ti
                      82 GS1000. 06 h3
                      82 GS750. 79 ta 6.6
                      69 T500. 80 gs1000
                      15 sonic 82 cr480r
                        You can get legit street use steelies, 14x5.5 Dual bolt pattern ET35 for $38 a piece, and have much less issue with both fitment and balance.
                        Will Samet
                        How to find me:
                          Didn't someone on here just buy a set of the ones you mentioned??
                          CURRENT. Past
                          14 foST. 89 xr4ti
                          82 GS1000. 06 h3
                          82 GS750. 79 ta 6.6
                          69 T500. 80 gs1000
                          15 sonic 82 cr480r
                            I know at least one person posted about it on the facebook page.
                            Will Samet
                            How to find me:
                              What size tires would you run on that, 165/45??
                              CURRENT. Past
                              14 foST. 89 xr4ti
                              82 GS1000. 06 h3
                              82 GS750. 79 ta 6.6
                              69 T500. 80 gs1000
                              15 sonic 82 cr480r
