what is the camber and caster angel of festive
camber angle *
Front 0 degrees 40 +- 55
rear -14+-34
So Brian is saying:
Front is 0 degress, 40 minutes and the tolerance is plus or minus 55 minutes.
Rear is 0 degress, -14 minutes and the tolerance is plus or minus 34 minutes.
Just take it to the alignment shop. They should have all the specs. Or are you doing it yourself?
Camber: 0 degree, 40 minutes and the tolerance is plus or minus 55 minutes
Caster: 1 degree, 35 minutes and the tolerance is plus or minus 15 minutes
Toe-in: 0.5 to 6.5 mm (0.02 to 0.26 inches)~Jeff
1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
2003 Mustang GT 5speed
Re: camber angle *
My manual for 92-93 shows:Originally posted by Ahmed el ShallWhat is the camber and caster angles of festiva?
Caster Angle, Degrees
Limits positive 1-1/3° to positive 1-5/6° Desired positive 1-7/12°
Camber Angle, degrees
Limits Left & right negative 1/4° to positive 1-7/12° Desired positive 2/3°
Toe-In, Inches
0.02" to 0.26"
King-pin Inclination, Degrees
14-11/60°1992 Festiva GL 1.3L
Automatic
