Is there a bolt on coil over kit for my 93 Festiva?
  • Is there a bolt on coil over kit for my 93 Festiva?
    Is there a coil over set that bolts up to the festiva that doesn’t take to much fabrication to the oem mounts? Thanks in advance!
    Allen
    Welcome! And Yes. No modifications to the oem mounts on the car but you have to do a little work to the kit that you buy. The writeup is here of what to buy and where to get it from
    If you are looking for a great street/track suspension that won't break the bank or you just want an upgrade to the stock suspension this is for you. I will go over each step in the order that i did them. I am sure you could do them in another order however this is just what i did. I will give as much detail as i can. I will
    Will make your car handle like the sports car that it really is
      BWAAAHHAHAHAHA!!!!!
        Cant find anything about coilovers which ones should I use for standard suspension. I want the car to not be so low.lol.please and thank you in advance.
