Honda VX 13" forged alloy
i think most of the people off honda forum pick thier's up fairly cheap 100-180 for a set.---------------------------------------------------
negative, it's the 4x100 bolt pattern....you would have to do the aspire swap for them to work.---------------------------------------------------
alot of work, money depends on ur jy, you will have to pull the whole wheel system2007 Ford Taurus 23-25MPG
1976 Chevy Silverado (my toy)
1951 Ford Deluxe, being rebuilt
Have an old car truck or tractor? Go here.
http://www.aintperfect.com/
READ UP, Not that hard have done 3 festy's now. The biggest problem I've had is the bolt that connects the suspension freezes & you have to figure out somthing else, like torch it, cut it out/reweld it or purchase a new rear beam. I've had that happen to 2 outta 3 festys. Pretty much its remove festy parts add aspire parts.It's a good thing you don't read the stickies, you might of learned something.
Poverty produces creativity
