Festiva w/ aspire brakes & sway bar, car pulls
  • Festiva w/ aspire brakes & sway bar, car pulls
    I installed the aspire brakes with new rotors (I cross drilled them first) along with the aspire sway bar and energy suspension polyurethane bushings. I noticed that under torque it pulls hard left, but when off torque it returns to center. I assumed it was a bend in the sway bar (the only one I could find then) was from a bar that was bent little. I bent it back after heating it, but its more temporary because I took the temper out of it. I read the posts regarding slotted mounts for the sway bar that I think that might be whats happening. If anyone had this happen with the same results, let me know. I have cheap coilovers for a 94' integra which makes it handle very very flat through the turns. I have the rear torsion beam going in soon, so I will let you know how that works out. Thanks for the help.
    There is a post on the old forum about the slotted mounts and how dangerous they are. The sway bar on the festivas resist the wheel moving back and forth during accelerating and braking. They need to be secured so they cannot move for/aft.
    matt
