will 14x7 inch rims fit with the aspire swap and fms spring and struts
14x7in rims
I did 15x7 and they fit so as long as you remember: aspire brakes - (4x100) and festiva brakes - (4x114.3) you will be fine with lug fittment. Also remember your best fitting tire will probably be a 195/45/14, Toyo makes a T1R Proxes in that size which I have heard nothing but good about, Good luck and I hope I was able to help.
about half way down the page there the konig rewinds
I used those toyo proxes t1-s I think,All I can say is they are too soft.I went through the front tires in about a month and a half.This was spinning them in occations.I still have the rear up front and its been like 6 month's,They are starting to show wear now..Hook up its not that great...
check and DOUBLE CHECK your back spacing before buying rims and then leave some room for safety. you'll need about 3/8" between tire and any suspention component to compensate for tire squirm.Trees aren't kind to me...
