Hi All,
Been working on getting the front brakes ready to go under the festy.
Got the Bendix CT3 pn/D446CT front pads and the Raybestos PGplus pn/66468 front rotors for MTX. Got the whole strut/knuckle sitting on the bench. Got the calliper fully compressed (no really I do!). New rotor is on.
Problem: I can get the pads in place but they are tight up against the rotor. They go in easy but you could not slide a piece of paper between the pad and the rotor. Anyone running this setup? I see Packrat you are running these rotors. What pads are you using? I dont think they will work this close. The pads seem to be awfull thick. Are there MTX and AXT versions of the PADS? Any suggestions.
Thanks
Eric
Thanks
Eric
