Will these fit what offset is needed??
  • Will these fit what offset is needed??
    I have 15x6 now and they fit good. These are 15x6.5 with a offset of +38mm offset.I emailed them to get the backspacing.
    Also what do you you guys think of them?????
    "Look, I have long hair, tats and smoke like a chimney.. All of my customers know it.. Don't like it? Don't turn over my rock."
    RIP DJ
    Find the offset of your current wheels and then look underneath to check clearance from your suspension parts. If you still have Festiva rear struts, getting Aspire rear struts will give you about 3/4" more clearance for the tire.
    My 13 X 5.5" VW alloys have a 38 mm offset ("ET38") and fit really nice with the Aspire rear struts. However, you will probably be using larger diameter tires (195/45 or /50-15s) and your inner rim will be 1/2" closer to your suspension.
    I'm pretty sure others have used 15 X 6.5" wheels, and the 38mm offset sounds about right. Also check for fender clearance, especially if you lower your car some.
    Karl
      Those rims look great. I'd always liked the styling of the 'rays' type wheels. Also- The Australian recommended offset is +44, although i agree with Safety Guy- 38 is the best shot....
        ^^^15x6.5 38mm offset 195/50-15 ^^^ on Aspire suspension. Clears the suspension fine, may rub on the front fenders, haven't driven it yet.
          holy clean batman!
          BP powered 91 Festiva L
          -FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
          -Trunk mounted gel battery
          -Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
          -Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
            That is what I am looking for 8)
            I have coil overs on the back and the spring pearch is cut flat with the shock, so I have good room back there.
            Thanks for the replies
            RIP DJ
              That looks awesome! If you lowered the back, would the tires still fit?
                Not sure.
                I'm in the middle of an Escort GT independent rear suspension swap right now. When that is done they better fit.
