My festy need a brake job, (including drums and rotors) so i figure why put money into the stock system. What better time to do the swap!
1st question. I understand with the bigger wheels the speedometer will be off. What can be done to correct this? Where dose the gearing change? is it the spedeo gear in the tranny thats different, or is it in the cluster that the gearing is different?
2nd question. How will the added weight/ bigger tires affect gas mileage?
3rd question. Struts and coils- are they different between the two cars? which should i use?
ways) of putting a 175/60 tire on a 4.5" wide rim, others have apparently gotten away with this for years with no problems. So putting those on Aspire steelies or alloys should be fine. One reason I went with 165/70s on my Aspire alloys was to put the maximum rubber on those skinny wheels as I could stand, since I'd want a minimum of a 5" wide wheel for the 175/60 size. The main reason, however, was that running a stock size Aspire tire would give me a more accurate speedo reading when I swap to an Aspire ATX. The Aspire tranny also will give me a lower final drive ratio for quicker takeoffs.
Poverty produces creativity
Especially on a live rear axle beam.
