Friends I have a Kia Pride with rims Hoop 12", want to put great hoops and rims to him but. As it is the recommended size. Thanks, Jochelo
That so large of Rims to put
^^i think might be able to fit 16's without major modifying
yeah D's car has 16's on it, i have 15's and im lowered and get crazy mad rubbing, id recomend some fender modifications and some aspire springs/struts (kia avella possibly in your country?) to raise the spring perch a bit to help with tire clearance.
funny lol, D just called me while i was typing this haha1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
Size of rims
Hello 25Horseplay, your car this as we say aca in Peru... Bravazo , tell me that measured exact of rims you have put to him to your Festive one, I him probe 195x50 R15 but it hit, I imagine that habras changed the shock absorbers to him, tell me that it marks you put to him. Aca in Peru Lima "CONTROL" commercializes them, that are Korean and the "GABRIEL" who says is of the USA, or is that you put something to raise them to him. Thank you very much, by its aid. Jochelo :cam:Originally posted by 25HorseplayHow about a picture!
*Size 15s rims can be installed into your ride, using 195x55 or 50 or 45s R15, the downside is that the ride height may just be too high.
If the size 15s rims has a deep center, this may rub against the shocks, if spacers are used to allow clearance for the rims not to rub against the shock/body, the lug nuts may not be long enough to reach the hub, so that will entail a purchase of longer lug nuts.
Going further, if the install of rims are done correctly the next problem is body roll that cause the frame to rub against the tyres, use of stiff shocks or stonger spring rate is needed.
Do you have any pictures of D's car with the 16 inch wheels? All I have is a small picture on my phone.Originally posted by IdealSocietyyeah D's car has 16's on it, i have 15's and im lowered and get crazy mad rubbing, id recomend some fender modifications and some aspire springs/struts (kia avella possibly in your country?) to raise the spring perch a bit to help with tire clearance.
Thanks for the aid, it seems to me that the measures of the rims that you have in your Festive one are the ideals. It seems to me to understand that these using the original shock absorbers of the car, and single you have changed the means. A consultation, that mark of Rims and model these using, in Lima-Peru is Sumitomo, Toyo, Dunlop and Good Year. Excuse that my consultation is so extensive what happens is that in Peru there is modified Festiva and no Kia, the few that there is are used like Taxi, single some as mio is of particular use. Serious good for knowing of you traves of our forum www.todoautos.com.pe, from already the invitation this done. Greetings, Jochelo
