I just replaced both ball joints/control arms on my 90 festiva and i am having a hell of a time getting the sway bar back in the control arms. The new bushings are to new and i cant compress them enough to get the retainer and nut on! Any suggestions, comments ideas!
sway bar bushings
liquid soap, WD40, brake fluid, KY, etc.!
Peferably something that will not breakdown rubber.
Use as little as possible and when you can start the nut on the threads tighten it down is stages!
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
:lol:Originally posted by Pu241liquid soap, WD40, brake fluid, KY, etc.!
Pu241
There a pain man, I even took a razor and trimed mine on one side they was so bad. Better off have 2 ppl, 1 with both hand push washer dwn and one to start the nut."Look, I have long hair, tats and smoke like a chimney.. All of my customers know it.. Don't like it? Don't turn over my rock."
RIP DJ
Just trying to provide useful information that may well be useful in other areas of life!Originally posted by Sho_tyme_psi:lol:Originally posted by Pu241liquid soap, WD40, brake fluid, KY, etc.!
Preferably something that will not breakdown rubber.
Pu241
please note the lack of recommending Vaseline which is known to degrade numerous types of rubbers! :wink:
Originally posted by oxbrain....Have a fat friend sit in the car and lift up on the hub to get it aligned.
I resemble that remark! :lol:
To properly do this, you need to compress the front suspension as if the wheels were resting on the ground. You can put a jack under the ball joint to do this, or put the wheels back on and lower the car down onto ramps.. Either way the closer the LCA is to horizontal with the ground the better/easier it is to do. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Proud member of Chicken Mechanix Racing
