ok i need to get better traction.. right now i have the FMS suspention front and back.. i do not have aspire swap... but other than that what else can i do for traction? kinda vague i know but i would like any ideas i can get to try and get my b6t festiva to catch traction.... please pm me an idea's.
traction
yea id say so. but do you know fo anything else?
also how much does the front strut tower bar help out for traction? im in themiddle of making one.. but wanted to know how big of a differance it will be?1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
1993 BBF 466cid mustang notch 7.7 ltre
festiva turbo b18 project
2001 BMW 325i
1996 ford F-150 sold
also would i be better off replacing my rear fms srpings with some nice stiffer ones? if so which should i look for?1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
2001 BMW 325i
how well does it work.. and how did you make it? i was thinking of trying it but didnt know how to go about it.1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
2001 BMW 325i
well if i dont have one by then lemme know what you come up with1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
2001 BMW 325i
These are the only two I can find.
Well I found those on honda tech and it basically bolts to the top of the Ball joint to limit the wheel from hopping all over, it also looks like it limits front suspension travel a bit too.
I'm guessing have a removable bar go across the front of the car that has two little bars going to the balljoint. Youd have to get one that was solid instead of grease filled and have a little flat piece go under it.
