I have this carburetor 1981-1984 Ford Escort 1.6L Mercury Lynx 1.6L New OEM Motorcraft Weber Carburetor. My old Aisan Carb for 88 ford festiva LX. the Aisan carb. has a forward pull on the accelerator cable, but I need to get a kit because the new weber Carb has a rear pull, what kit would I use? What have you guys used to do this?
Redline Carburetor Linkage Conversion Kit????
I cut down the stock festiva cable wheel to get rid of the unneeded tabs and tack welded it onto the shaft of the escort carb. On my escort carb there wasn't enough shaft sticking out to bolt it on.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
