Here are the front fender plugs, after they are finished ( a few more hours of sanding etc) I'll use these to make the molds. Im happy with the shape. I wanted a "squared off " look at the wheel opening vs the round ones of the originals. Once I get the drive line back in I can start on the rears
miniguns fenders ( plugs)
How wide are the fenders?Festiva: Because even my dog can build a Honda.
How much for a set.....?1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
Very nice work!!!
Hot Wheels, use YouTube, there's all sorts of how to's for molds and fiberglass.
BTW, i want a set as well, how much??Trees aren't kind to me...
I need a fiberglass body here in Illinois , pretty soon , I will be stopping like Fred Flintstone ..LOL
Those fenders looks awesome !!------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Got a call from the machine shop to come pick up my stuff !
BLOCK, 1994 3.0.....
hot tanked, magged
bore / honed .120" over to 3.2 factory specs .
HEADS
24 valve, 3 angle valve job with oversized valves .
Assembled with new seals, bronze guides and new custom springs ( I supplied all parts ) Now I have a place to put those custom ground cams !
Total $ 675 , I had one place quote me more then that just to do the heads . Now I can take a break from body work to put the drive line back together, then I can start on the rear fenders once the rear tires are back on.
I also changed the design of the front fenders a little...
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
i really like those fenders!! your car is going to look amazing when finished!!
