Lol ya I get told that a lot :lol:
I decided to borrow my brothers car for work tomorrow so I can relax the rest of the night, I'll finish it up tomorrow after work
I've basically had to tear down both engines to almost block/heads, the pass side water outlet needed to be changed on #2 but I had to pull it from #1.... Pulling the water outlet off means pulling the timing belt, pulleys, cam pulleys etc. basically the entire front of the engine
The reason for needing to change that piece is because the coolant temp sensor and temp gauge sensor are located on it, the outlet on #2 got modified for a different temp sensor from when it was in the P5, so I needed to get an un-modified one installed to have the coolant system sealed
I also re-did the oil return bung on the oil pan, Charlie suggested that maybe my bung was too low in the pan and if it was getting submerged in oil, it could create draining issues for the turbo, so I figured now was the best time to change it since the pan had to come off anyway to be transferred to KL #2
I spent a LOT of time transferring parts, a lot longer then I anticipated, but like I said, it should be up and running tomorrow night
