Got it right this time
fits perfect now!!
I also brought some other parts into work that needed a bit of work, since i had to cut around the rad support for clearance for the alt. etc. i lost the bolt holes for the trim piece below the headlight and 2 out of 4 mounting holes for the headlight itself
In this pic you can see how i moved the bracket over and re-welded it, and that metal is extremely thin so it burned through very easily
And a self-tapping screw to bolt it in place
For the headlight i welded a little tab on it to make a good point to bolt it to the body and it works pretty good
And everything looks factory again once all the pieces are put back on
Once i got those little detail things taken care of, i pulled the engine back out so i can change out the broken water outlet on the engine
And what a PITA it is to get to, i have to take all the timing belt pulleys off in order to get to the bolts
and the new part ready to go on
i got the new one installed and got most of the pulley's back on but i had to stop so i could pick up my girlfriend from work (she'd be a bit mad if i was late :lol
, so i'll finish it up tomorrow
