Matts B3 Turbo Build
This topic is closed.
    Originally posted by takeone51 View Post
    when are you gunna sell upper intakes and the valve setup?
    When someone buys them! Valves and springs in stock, intakes built per order.
    PROPOGATE! AND FACILITATE!
      BP intakes as well?
      It's not the size that counts....It's how you use it.
      90 L 5spd- BP project
      90 L auto-rusted out and wrecked used as a parts shed
      89 LX auto- sold to a friend
      89 L 4spd- Gave to cousin as a first car
      95 Honda Civic EX
      99 Jeep Cherokee SE
      07 Mazdaspeed 6 GT
      07 GSX-R 600 K7
        Originally posted by gtk7 View Post
        BP intakes as well?
        can do!
          That's insane... such clean work.
          Awesome.
            Nice looking work Matt. How much boost you planning to eventually run?
            1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
              For now 6-8psi , I'm going to install a 190lph fuel pump to get me by, eventully i'll install a new feul system ,cell , larger lines ect, with an aeromotive a1000 pump.After that I'll crank the boost up till a larger turbo becomes necessity.
                thats alot of craftsmanship. you have skills!
                  wow
                  • #24
                    pm'ed
                    • #25
                      Should be a fun car. Even a stock b3 on 10psi with a vj11 is fun so this should be much more so.
                      • #26
                        That is awesome!! :thumbright:
                        -85' Nissan Sentra 5 spd.
                        • #27
                          just curious if you made the manifolds for bps exhaust or intake how much would they cost. pm me if you want. thanks
                          • #28
                            What kind of power do you expect at the 6-8 lb level?
                            • #29
                              Very nice work! If you don't mind me asking, how much did the ceramic coating set you back?
                              • #30
                                I just wanna know total costs if someone were to call and say "build me one"
                                -Greg
                                Redneck Engineer
                                FOTY - '09
