doing final stuff to rear bumper, its saggin a little because its just hanging, not bolted to mounts.
Im going to use square exhausts tips , should I have them haning below the bumper or notch the bottom lip and have them sitting higher ? I think they would look better in a notched bumper.
NOTE, the black cable is part of the clutch, it will be tucked up, the other two pipe are part of the exhaust, not much I can do about them , ran out of room
I have noticed that the tail lights will be block when viewed from certain angles from the side. I may install small marker lights in the rear fender flares behind the tires.
