…. Brickdog2000, did you use this adapter plate or did you go with the thinner laminated aluminum one later on in this post that zoe60 used? If you did use this one, from the pic, it appears almost too high between the intake manifold and the bottom of the “Carter 32/36”. I am still playing catchup on this, maybe you can clarify and why. :confused1:
Thanks
Thanks
Originally posted by brickdog2000
