My names Andrew, and i now own 2 Festivas.
So here it is.
1992 Festiva with a b6 na motor turbo'd with a ford mustang svo turbo. You can see the difference between my stock 88 carb and 92 turbo lol.
I recently purchased this car from. (baltzersen82)
It has a few issues that hopefully i can fix.
Power is fantastic. Boost comes on a little later than id like. But when it hits. WOW!!!
Heres a couple of shots of the engine.
Car is deffinately not perfect. But it doesnt need to be. my other festiva just turned over 73k and its my a-b car. This one has considerably more. 160k+
The interior is fairly nice. Needs a couple bits here and there.
Stereo is nice.
But no rear speakers at the moment.
All in all its a project. I hope to use this tread to keep my progress updated.
1st Concerns.
Rear Wheel Bearing.
Front Suspension's pretty bouncy, not sure if thats extra weight, or just bad struts.
Injectors (im told) are 80lb. I need to find out for sure, either way, WAYYYY to much fuel. With a little help from HofficerGrover i plan to put smaller 323 gtx injectors in. Currently when i hit about 10lbs and shift the car stalls. Black smoke a plenty. Car idles high, and stumbles at low end. Hopefully all these problems get fixed with different injectors.
Id like to install a (new Boost Gauge one that measures vacuum and boost), Tach, and WideBand Air/Fuel sensor.
Currently (Right now 12:58 11/19/10) its failing inspection here in PA lol. He will give me a list of minimums i need for inspection, and ill go from there.
Thanks for watching.
So here it is.
Stereo is nice.
1st Concerns.
Rear Wheel Bearing.
