I don't know if I would want to go any darker than my current VX wheels. It sorta hides the actual rim design that I like. I was thinking even just a tad lighter than the VXs just because I think it would look good with my future blue.
xaero_81's B6T/G25MR Build Thread
Hyperblack wheels. It would make that blue explode.In love with a MadScientist!:thumbright:
I still owe you and Hazzbee a VAF adapter... I'm working on getting them done man I'm sorry it's taken so long1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
^Excellent! Got the first coat on one wheel. I'm using Duplicolor HPW102 Graphite. Wheels have a pretty grainy texture to them so I figure ill do about 7 coats of clear to smooth them out.
Before:
After:
Not the best "hyperblack" look, but for only $32.xx in supplies I couldn't say no.
Yes, and yes it is.Originally posted by M3NTAL View PostDid you paint your exhaust manifold on your b6t? I hope it's jet hot 2000 degree paint
This was one coat. Just did the other 3 this weekend. They look pretty good in sunlight unlike the grainy picture above.Originally posted by crazyrog17 View PostThey look good IRL too! Did you do the clear coats already or is that just the graphite paint so far?
Also, in exchange for my painting skills, Brad finished up my wiring so now all I need to get it started is get some new plugs and wires, install battery in the rear, and piece together intake and IC plumbing.
Wow donny, looks like instead of getting your B6T done, you just wasted a bunch of time.
And how come you didnt tell me you were going out there?
What a douche.
Youre hubcaps look like brake dust.91GL BP/F3A with boost
Separated my VJ11 compressor from turbine, now just need to do the same to the 14 and reinstall.
Got my tires onto my HX wheels (special thanks to Crazyrog17 for sourcing the work to his dad). They're no longer only 12lbs. I'm going to try to remember to weigh them before I put them on so I can compare to the stock Festiva wheels.
Also got my 5/16" spacers, 45MM wheel studs, "tuner" lugs and Loc-Tite but ran out of time this weekend to install. Going to have to order another set to do both cars next payday.
Bought some NGK Coppers too but does anyone have a recommendation on plug wires?Last edited by xaero_81; 11-07-2011, 03:56 PM.
