Its a fantastic system, yes - for a "stock" B6T? not ideal when there are much easier and cheaper solutions. When you are running a turbo well over 400cfm or you need electronic ignition control - go for the Haltech, or check out Megasquirt as a budget standalone solution.
b6t swap in 1988 festy
1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Originally posted by 1988festivazoom View PostSolid front mount and puck clutch but power wise will it handle 200hp? I got the tranny for free and have 2 of them so I'm figured I will just use it till it blows lol
Having the mounts and the clutch will help, but that won't really do much for the case flexing when it feels like it. With enough grip/traction/stability from the mounts, suspension, clutch, engine, and management system, the limiting reagent will still be the transmission's integrity, especially at close to 200HP.
Have a look at this quotation from the Manual Transmission Swap Thread:
"Now you are asking, “What if I really want to get on it every once in awhile?” Here are some suggestions for max horsepower to place through these transmissions based on being somewhat rough, not babying but not thrashing. For the E-series transmission, I would put the max at somewhere from 80-100 HP. For the F-series, I would put the max between 140-180 HP. For the G-series, the max has not been truly defined, but I would guess somewhere around 250-300 HP, though it has been seen to withstand over 400 in a daily driver. Remember, these numbers are just suggestions for the festiva. Since the festiva is a lighter car, it does not put as much stress on the transmission as would a heavier car. If you are planning on carrying extra weight, I would lower these numbers accordingly."
You're also going to have to mitigate the unequal length axles, and a limited-slip differential won't cure those woes, but they are available... Phantom Grip makes those insert ones with the springs. Reading up on that transmission link will also help with traction... the final drive differentials make a HUGE difference between the 323/MX-3 zippy transmission and the top speed/cruiser transmissions in the Escort Pony and Protege.
Originally posted by Rocketman View PostInstalling and trying to tune will be 100x harder than swapping harnesses, and much more expensive1988 Chevy Sprint Turbo 997cc
Thanks a lot for the info! I don't really car about my freeway rpm at all I'm just looking for something that will handle the power and I didn't want to do the g series swap (haven ead much) but I thought u had to cut the body to fit that tranny like an escort gt tranny. Correct me if I'm wrong. And do the g and f series share the same mount placment bc I already have a modded x member for the f series.
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
I see Ur festy is a 88 so it was carbed , I'm doin the b6t swap in mine right now (89 festy) and cannot find a write up on the wires u cut on the festy to give u ignition power ect..1988 ford festiva-b6t in the works
1992 ford mustang gt - 12.49@ 108mph mild bolt ons n/a now single turbo setup dyno #s and times soon
2001 dodge ram cummins - edge juice with attitude,injectors, fuel system, built trans
I attempted to do what you are doing. Here is my advise. I spent over 2 weeks trying to make it work by piggy backing computers wiring/ tracing wires ect. In the end I just went to a wrecking yard and pulled a complete harness from a festy and did a full swap. Its a pain bc u have to take most of the interior out including the dash to make it simpler. But the end result is a clean harness and no stray wires. I payed 40$ for the entire harness bc junk yards don't think festivas have any value. If u can't find a full harness I can get one from a junk yard for u but I will have to sell it for problay around 100$ bc I'm gunna spend a fiew hours getting it out of the car. Plus the cost of the harness and I will ship it for free.
sponsered by,
Zoomy didn't you convert to an EFI harness? These links spell it out for you...
Rocketchips!
Well I was thinking of doin it that way considering i know where my old 92 is sitting in a field, may be the best way cause my interior is already out of it1988 ford festiva-b6t in the works
Save the headache... do the complete harness
sponsered by,
Ok question for the swap....
Can I use xr2 cv axles and the halfshaft assembly with aspire hubs?
Are they the same spline count and size?
Are they the correct legnth?
sponsered by,
sponsered by,
i got 323 gt axles in my swap, and i have the aspire swap... no problemslots of people have done it....
Mike, AKA the sasquatch
Ok just wanted to check b4 I go getting all the parts for it. The jy wants 10$ for the passanger half shaft! That will save some $'s. They have a spare knock box too if anybody wants it?
sponsered by,
t3/t04b hybrid turbo i rebuilt for the b6t
sponsered by,
intercooler 2.5" pipes soon to come! should fit next to the factory rad.
sponsered by,
xr2 capri intake complete i got on ebay for 125$
sponsered by,
