Why am I only seeing this now? This is amazing, just like I thought it would work! As far as your bumper turn signals, you can drop them entirely and pick up a set of driving lights (LED, or halogen) that will mount easily inside the housing instead of having to source a location to put them below that.
If you choose to upgrade to projector lights, which can now be done, the turn signal can be re-routed into the side markers by using the AutoZone cuttable, flexible LED lighting strips. Just drill a hole into the corner of the lens on the inside, and feed the lights through it and to the other side. Make sure to use silicone at the very ends to both secure and seal the lights inside the housings. Note: The lack of draw on the turn signals will probably necessitate a resistor to keep the turn signal relay from going nuts, but trust me when I say that after all that, it'll be worth it. Just wait until I drop the whisper of my tail-light mod...
In love with a MadScientist!:thumbright: There's a fine line between breathtaking ingenuity and "That's the stupidest thing I've ever seen!"
You could replace the flasher module for one that's purely digital. Flashes at the same speed no matter the load. Only bad thing: you don't know when a bulb is burned out. Good thing: LEDs never should!
-Zack
Car was sold to a family member. I still get to do some stuff to it though (with permission!) basically the only thing thats happened recently is a lot of driving. Its in desperate need of: Pair of struts, alignment, New exhaust,tuneup, oil changes are in order. I'll probably do some work on the grille while I have the car in my car for the next few weeks.
Previous:
1991 GL. (01' ranger lights!) P/S,A/C Sold to Mum.
1990 auto. hacked up rally toy.
1988 5 speed. The pile
1993 5 speed.
1995 5 speed aspire. Gutted for the 90' auto.
