I've had issues with the cluster lights on the right side of my cluster since it had 12K miles on the car. I saw an LEDstrip at Walmart that looked like it would fit the area that the bulbs fit into. They are 8", Blue and cost about 13.00 per pair. I hooked them (actually one of them) to the standard light connection so the dimmer still works. I'm running them on low (dimmed to the minimum).
Attached is a link to the video I made last night. The quality is not to my standards but it will give you an idea of what is involved in the mod.
The directory has 2 videos. 1 in the car of the dimming action, the other of the assembly of the cluster. I call it the BeBandit LED light/gauge cluster mod.
It was debuted at Carolina Spring FestivaL Saturday night
. Did you keep the regular bulb behind the ODO?
