It lives! Rather loud, and pretty fast. It's a ton of fun. I think the computer has figured out the idle at this point, it seemed better after a bit of driving. Unfortunately, it looks as if the valve seals could use a bit of work as there was a fair bit of blue smoke on startup this morning. I'll keep monitoring it.
My Build Thread
Good news, Bad news. Good news, it's probably not the axle seals leaking tranny fluid, bad news, I need a new speedo gear seeing as the stock one from the protege decided to depart during today's test drive. The cable wasn't attached and I just had it in there by Friction but I figured that was good enough, apparently not... The old one might be on the driveway (Long gravel road) so I'll search tomorrow in the light.Owner of:
1991 Red Festiva L, 5 speed (Swagger Wagon)
In progress:
BP+G25MR swap, Kia rio axles hopefully.
Long time no post. I was at college for the last nine months at beautiful Cal Poly, San Luis Obispo for Mech. engineering. I will be dragging the car out from under its over today, it was in rough shape over spring break with a 5 year old walmart battery that is almost flat even with the float charger on it. I'l also have to pull the rubber cork that I rtv'd into the speedo hole to prevent it from barfing atf everywhere to check how much leaked out. This brings me to my question.
I have the G series from a protege but lost the speedo gear, what cable/gear combo will get me a working speedometer? and an actual dipstick in the trans so I don't have to use my finger and guess where it's supposed to be.
ThanksOwner of:
In progress:
I don't think we can do anything about not having a real dipstick in a 5speed.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
