B6 swap underway!
  • #16
    progress has been hindered by a pesky water leak from the lower coolant pipe. tried 3 times to get it sealed but it still leaks...grrrr.
    07 Chevy 1500. 5.3 E85
    91 Festiva DD B6, M5, AC, PS
    90 Festiva figure 8 racer
    90 Mustang LX, LSX, 4L80. AFONOMO
    • #17
      found out the cause of the water leak, lower pipe was hitting the AC and binding it up making it leak. got it all fixed and got the intake piping routed and fired it up! runs pretty good, just needs a little tweaking and gotta adjust the new clutch. hopefully on the road soon!
      • #18
        Congrats, you are gonna like the b6.
        • #19
          Have you switched it over to a B6 ECU yet? If not, I believe there was one posted in the "For Sale" forum.
          • #20
            still gotta get the b6 ecu in, hook up a crankcase vent hose, fix a small water leak, and get the clutch adjusted. the ole junkyard motor run pretty darn good so far. used the factory festiva rubber intake hose with the intake hoses from a early 90s caravan to route the intake piping and it turned out perfect! will update once i get it out on the road and will compare its speed to the B3 and to some of my other cars (we have a strip where we test all of our cars to see how fast they are: stop light to bridge. 100mph is pretty fast. stock festiva does 67, my capri xr2 does 95, grand prix gtp comp g does 101, and my brothers turbo ss cobalt does 110)
            cant wait to get it on the road again!
            • #21
              Cool routing on the air intake, I used a different route
              • #22
                i was thinking of doin it that way too but i had more room to work with going the long way. and the piping i had to work with happened to work perfectly lol. im sure ill keep fine tuning it over time because nothing is ever "finished" lol
                • #23
                  clean!
                  Never Hire a Boy to do a Man's Job!!
                  • #24
                    Good going!
                    (You know if I had a shop and hoist I wouldn't be so lazy!)
                    Karl
                    • #25
                      haha its easy to have ambition with a hoist!
                      bad news on the swap, was fighting clutch trouble and figured out i prolly put the disc in backwards
                      ive done countless clutches and even put one in at the racetrack before but never put a disc in backwards.
                      so out with the trans to fix my screw up!
                      • #26
                        Ouch! Well, that'll learn ya to do it the right way first!
                        Karl
                        • #27
                          Bummer ! Sounds like something I'd do, Im wrong 90% of the time on 50/50 decisions.
                          • #28
                            sounds like my luck
                            • #29
                              ^LOL ! I saw what you wrote before you edited. Its been documented.
                              • #30
                                I can't believe I did it lol, I always check stuff like that cuz I HATE doing something twice. Lesson learned
