shorestiva crys havoc and lets slip the hogs of war
  • Originally posted by shorestiva View Post
    13hrs and 440mi later I have all the transmissions I need to build the one I want.
    Explain please!!!!
    • kia sephia?
      Mike, AKA the sasquatch
      • The one on the left is an escort gt trans
        Ford Fester
        • Re: shorestiva crys havoc and lets slip the hogs of war
          Left is 97 escort right is kia. I wanted the longer final drive like my cable g series has. But the early g series has thinner gears and I'm not sure if they'll drop into a later case. The solution is the 97 escort trans. The bellhousing is for a Ford 2.0 sohc so you have to take the gearset and swap it into a case that will bolt to a b series in this case a kia one. Then I add in the mfactory diff from my cable trans so it all will work with my gt halfshaft and axles.
          Sent from my C771 using Tapatalk 2
          Better Than Nothing Racing
          Way too many cars
          :woc:
          • shorestiva crys havoc and lets slip the hogs of war
            ^^thats what I plan to do with my KL trans one day, whenever I feel like getting to it lol
            But the EGT and cable G series trans each have the same ring/pinion gear thickness, once you confirm that for yourself, I'd be interested in the 97+ escort trans
            • Bunch of goodies have been showing up lately.
              Test fitting the new radiator
              And found out that hydro trans have different mounting points than cable.:banghead:
              The back mount will bolt up to the trans but aparently the case dimensions are different and now it wont clear the rack.
              Way too many cars
              :woc:
              • thats a kick in the bolts.... lets hope its not to hard to fix the mounts...
                sweet rad, that should keep it nice and cool any reason for a full width rad and not a half rad like a civic one? mine has no problems keeping my bpt cool...
                  No real reason other than I figured a little extra cooling capacity wouldn't hurt.
                  Way too many cars
                  :woc:
                  • it will match your huge intercooler lol...
                      I'll use the kia trans I said.... it'll be easy I said
                      So last night I swapped my mfactory diff into the kia case so I could put my axles in and position everything to start on the new brackets. Once I tried to put the halfshaft in it became very clear why nothing is lining up. For some reason they rotated the back of the trans down an inch compared to the older cable trans. So now the halfshaft hits part of the oil pan right by where it goes into the diff. Also it won't bolt to the block anymore. The holes are an inch off and its closer to the block so when the bottom of the bracket is touching the block the top is angled out a good 1/4-1/2". The only up side to all this is that if you put the axles in the same spot as before the motor now sits about 1/2" further back and 1" higher.
                      Way too many cars
                      :woc:
                      • Better Than Nothing Racing
                        Way too many cars
                        :woc:
                        • you should just put in a bp, i think they are ment to go with that trans you have...
                          • Only thing that would help is the oil pan clearance.
                            Didnt have any metal to start on the mounts so I did this instead.
                            Way too many cars
                            :woc:
                            • what are your plans with the intake? hack off that throttle body too, put a flange on from a 5.0 mustang or similar and run a bigger tb. the only option for a throttle body for the miata is the skunk and its like 300 buxs. i just picked up a 65mm 5.0 tb for 40 buxs!
                              • ITB's?
