Yikes on the tie rod ends I'm taking the ebay gamble with mine and I got control arms and a tie rod ends for about 80 shippedt
My last engine swap build thread, FANTASTIVA
Originally posted by Damkid View PostWhen I did my BP swap I remember taking the stock festiva dist. connector, adding the 4th wire to it and running that wire to the ECU, that's all I did for the distributor wiring
Thanks Kid !! Ok, here is what I did. Took a wire from the EGT distributor plug and added in the the top or foward most empty spot on the stock festiva plug as shown below.
Does in go in the 10th postion in the yellow plug as shown below ?
I got aspire ends, Ill will check the price on some Escorts. Any particular year or model escort ?Originally posted by KingFish View PostDid you use the Escort ends or the Aspire ends? I remember reading the Escort ends are the same (abid a diff number) and alot cheaper.sigpic
^ yea yr/m/m does matter, but i don't have an answer, safteyguy Karl does..
Either advance or autozone had aspire outter rod ends for like 30$ each.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I can't remember exactly which location on the ECU that the dist wire goes to, but it looks like your doing exactly what I did
Its got to be right then !!Originally posted by Damkid View Postbut it looks like your doing exactly what I did
Then the only other wire would be the VICS Black/red wire to the 4th position at the ECU plug ?? Then I just use the ISC plug in place of the stock festiva plug ? Sorry for all the questions. I figure dumb question are better than dumb mistakes.sigpic
Originally posted by zoom zoom View Post^ yea yr/m/m does matter, but i don't have an answer, safteyguy Karl does..
PMed Karlsigpic
Other then that I can't remember the ECU locations for the wires, it sounds like you have everything under control and on the right track
Incorrect, the peter principle has been in effect for some time now.Originally posted by Damkid View Postit sounds like you have everything under control and on the right track
Thank you sir !! Feel free to point out any mistakes you see so far.Originally posted by FB71 View Post91 to 96 Escort, any model.sigpic
^^ wooow.. wonder what the difference really is?2008 Kia Rio- new beater
Pics of the final front motor mount. Of course the hydraulic clutch cylinder was right in the way. Use parts of two of the orginal EGT mounts. Its solid and there is plenty of clearance for the clutch and radiator.
Here is the full custom BP containment system. Short of a nuclear attact its not going anywhere. Finally free of the chain hoist.
The motor is in permanently. Tomorrow the front end gets installed.
