1989 Festiva L stalls, hard start....
  • LordOfTheCars
    replied
    I would have gotten back to this but I spent the better part of the last 3 days not feeling to well and the better part of today in the ER...
    I hope to get my *stuff* together and get a pressure tester on it in the next day or two.
  • Movin
    replied
    my 90 has a hose, and an Aspire I did recently had a hose.
    Neither had that symptom
  • tls_zx3
    replied
    i had all kinds of problems like this when i bought my car. i pulled my pump and there was a 1/4 tank of rust in the bottom of the tank lol. i emptied that out and cleaned it up and put the pump out of my sti in it. runs great now lol.
  • LordOfTheCars
    replied
    Well it does not just stall anymore...
    I did have a problem below 1/2 a tank that when filled ceased... Today I went down a rough country road and on a full tank it was doing the power loss at cruise speed. it drops down and comes back repeatedely... When I changed the sock in the tank the pump was rusty, I think it has some problems.
    Sunday I am going to add a fuel pressure guage to te car and drive it to see if the pressure drops... I had no fuel leaking through the regulator. I doubt it is the VAF.
  • LordOfTheCars
    replied
    Well I took it out today and it stumbled a couple times when it went half way between 3/4 and 1/2 a tank.
    I am going in to change the O ring, wondering if it's a strange pump problem... after filling it was well mannered... STRANGE.
  • georgeb
    replied
    ok, i guess the 89 sending unit is different than the rest of the EFI cars as well... learn something new every day!
    That type (with the O ring) is the only kind I've ever seen (2). 93 and 91.
  • LordOfTheCars
    replied
    If this does not stop the power loss I will be pulling the tank unit back out and I will snap a pic for reference when I replace the O ring.
  • FestYboy
    replied
  • LordOfTheCars
    replied
    likely it's the intermediate hose between the pump and top of the sending unit... they like to rot and loose seal.
    I pulled it out today, the pump output plugs directly to a steel line with an O ring... the tank sock looked like heck so I changed it, before I unplug the pump from the line I will obtain an O ring selection...
  • FestYboy
    replied
  • LordOfTheCars
    replied
    From 1/2 a tank down perfprmance takes a dive, What ever is going on I will be giving it a look see, could be that the tank sensor sucks and its actually empty or close to empty with a bad sock. What ever it may be I will hav to put some eyes on it.
  • georgeb
    replied
    There is no hose below the pump, only the sock.
  • LordOfTheCars
    replied
    Originally posted by Movin View Post
    I stopped at the 60 and that was because I was pin testing instead
    of using it, and yes, you bring back memories!!
    I try to convert our training, knowledge and high tech to something
    anyone can do...using easily obtainable tools.
    I just got an EEC V last year, I don't work at a dealer but I get my fair share of Fords... I picked the box up after I got an escort that had multiple problems in the harness... intermitant no start, no run and no charge all at different times...
    Someone did a motor swap and stretched the harness with an engine hoist....
  • Movin
    replied
    Originally posted by FB71 View Post
    that's called a break out box. Been around since the 80's. I have a 60 pin (EEC-IV) and 104 pin (EEC-V) and adapters for the carb, '89 EFI and '90-'93 EFI. I also have an EEC-IV Data Recorder (cassette recorder!). Ancient technology...
  • LordOfTheCars
    replied
    Well I have it sorted out...
    The stalling was the disturbulator, the stumble was at 1/2 a tank of gas and below, this means a hose below the pump. I filled the tank and took it up to 78 mph.
    Tomorrow I will pull the pump and fix the hose.
    My delima was I was looking for 1 cause not 2 and thats what made it strange. It acted like spark , then fuel...
    This car came out of a Mazda dealers stock, they sold it to a smaller dealer and I bought it. It was considered too expensive to fix. Had it not been parked for 9 months I could have gotten it with a good battery...
    Costs...
    Car $700
    Battery $75
    Dist $142
    Registering will be $25-$40
    Hose I have..
    Overall not a bad deal.
    PROBLEMS SOLVED
    Now on to the A/C and Heat.
