Man !, ya'll have a lot of bad luck. Hope that changes . Good luck on the repairs to both.
RHODES850 build/refurb
 Room Temperature Vulcanizing (RTV) sealant may or may not do the trick. Get a straight edge and check to see if the flange needs to have a few thou taken off with a flywheel cutter in a machine shop.Originally posted by RhodeStiva View PostI think I will remove and add rtv as gasket. That should seal it.
