my light no switch and no power to plugs i might look inside the hatch and tie the wires together and see if i get power there. i might do my own write up so if this happens to someone else.
RHODES850 build/refurb
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Just installed this
'92 Festiva L M/T
'93 Festiva GL A/T
On the trunk light, plug power/hot wire(white with red stripe I think), then make a ground wire to hook on other light connector & to a bolt screw/bolt. Then you can turn it (the light) on & off by the switch. I figured it out, & I'm old. You young guys should be able to.
Haven't try cassette. And removal this radio m havd slipped and i hit m wrist on some glass, I cut a tendon. Yea it's pretty deep but i cut my shirt and got my wife to tie it off so i didn't loose any more blood and kept looking for another hour around the junkyard. Now that's festiva heart, LOL;
'92 Festiva L M/T
'93 Festiva GL A/T
and it had the gtx speedo w/out tach.;
'92 Festiva L M/T
'93 Festiva GL A/T
See that white thing sticking out that is my tendon.;
'92 Festiva L M/T
'93 Festiva GL A/T
Originally posted by navdoc101 View PostOn the trunk light, plug power/hot wire(white with red stripe I think), then make a ground wire to hook on other light connector & to a bolt screw/bolt. Then you can turn it (the light) on & off by the switch. I figured it out, & I'm old. You young guys should be able to.
Originally posted by RhodeStiva View PostSee that white thing sticking out that is my tendon.In love with a MadScientist!:thumbright:
'92 Festiva L M/T
'93 Festiva GL A/T
yea i am buying one of those.;
'92 Festiva L M/T
'93 Festiva GL A/T
Check the tape deck before you buy one of those. I had a tape deck in my old AMC Eagle and it played cassettes at like half speed.
It works fine. It almost works like new just to old so I guess that's why it gets low stations only.;
'92 Festiva L M/T
'93 Festiva GL A/T
For the gauges in. Will be installing them this afternoon.;
'92 Festiva L M/T
'93 Festiva GL A/T
