So, since I've done some work and taken some pics, here's what happening with my Festiva build.
My MX-6 had the alternator go. Might've been the oil spewing out of the (I believe) front main seal that caused it to go. Either way, the car had it's final breath, and it was always destined to be a donor car anyways.
In progress of pulling parts:
Engine out:
Front of engine covered in oil:
Parts saved:
Ready for operation before getting scrapped:
Pulling the engine did a bit of damage, and I will be using this part in my build as you will see:
Tomorrow I will be basically cutting the front off the car off. It will find it's home (with a tiny bit of modification) in the hatch of my Festiva. This will give me all the mount points for the engine, tranny, and suspension which I will use on the Festiva. The track width is significantly wider, but according to my measurements, the fender flares I'm getting will fit the tyres quite nicely.
More pics to come.
Engine out:
Parts saved:
More pics to come.
