My n/a super b3 build
  • I like the idea of the cluster wrapped. It could look really good. If you did your wheels with it, and your tach cluster, I think that would be enough to set it off.
    • ok cool the nice thing about vinyl wrap is if you dont like it just peel it off.
      • Re: My n/a super b3 build
        Bert, the string starter was talking about unconventional ways of paint/color choice while waiting on the engine. Just pointing out how I did something odd.
        HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
        "CL4P-TP" - 93 Festiva L
        • Sorry just to re-iterate this:
          a b3 trans mated to a stock-replacement clutch took 266 whp? On planet earth?
          here i am babying mine with 150whp. maybe it really is all about the launches afterall...
            Yes but he did take it really easy on it also and he only had the turbo on it for like 3 months
            Sent from my LG-LS970 using Tapatalk 2
              Picked this up today
              Now the fun begins.
              • Looks good man!
                  Before
                  After
                  Having a solvent tank is well worth it.
                  • This is an awesome build.
                    What do you think your MPG will be after these mods?
                    • well not for sure but matt still gets 38-40 mpg with his... obviously depending on how you drive it.
                      • Hurry up and install in already everyone's waiting!!!!!!!!
                        • Is the current one he is referencing at 100hp/L boosted?
                            266 HP so 200 HP/L
                            91GL BP/F3A with boost
                            • The mpg at 38-40 is without the turbo. so he is at 112 whp.
                              Im workin on it but still have alot to do just picked up the block yesterday so i have to go through everything and clean it thoroughly to get any remaining metal shavings out. Then i need to get everything painted. then have to go through the blueprinting process, i have never done the blueprinting part so will be new to me and i will set up my gopro and put it on auto pics so you guys can see what i have to do. And if im doing it right....:nightmare:
                              • you do understand that blueprinting is just an extensive measurement and matching method. the better the measurement tools and more consistant the method, the better the results.
