My n/a super b3 build
  • Boy you sure made that engine look 'purdy'! Hope she purrs to top it off.
    • hahahahah thats a funny video havent seen that one yet.
      • thanks guys im glad you like it.
        • yowza!!!! your spending some serious money on a b3, spec clutch too!
          • This is gonna be good!
            Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
            • Re: My n/a super b3 build
              Yes sir stage 2 clutch... Just in case I do decide to add boost.
              Sent from my LG-LS970 using Tapatalk 2
              • Have you installed an oil pressure gauge? Considering the amount of money you have tied up in the engine, And the fact that it is all new, I think it would be a good idea to have a gauge to monitor at start up. There's a 99% chance everything will be just fine, but even a $20 gauge will work, all you need is a British pipe adapter.
                  Yup already had it installed before I started this build. I have a wide band afr, oil pressure, vacuum, and volt meter, all the gauges my stock gauges don't have. Plus I put a t in the oil pressure port so I can run a pressure gauge and keep the light in the dash so if I'm not watching the pressure gauge the light in the dash comes on at extreme low pressure.
                    Also I'm going to wire in a relay on the oil pressure switch for the fuel pump so it only runs when there is oil pressure.
                    • Good man.
                      • Originally posted by drumnerd33 View Post
                        When the engine starts there is minimal oil pressure correct? Wouldn't this me somewhat hindering in starting the car?
                        06 Jeep Cherokee Overland
                        95 Aspire (sold)
                          The pressure switch turns the light on at a very low pressure like 3 or 4 pounds... When you crank your engine over you'll notice the light goes out.
                            I did some research on it and a lot of people who run an electric pump end up wiring in a relay off the oil pressure switch and said works good and is extra safety if in an accident you don't end up pumping fuel every where cuz the ignition is still on.
                            • My n/a super b3 build
                              That is a great idea, I always prime my oil filter and bleed the air out if it. then pull fuel pump fuse and crank for oil pressure every oil change on all of my vehicles. I like the oil sending unit relay idea. Sounds like something I would come with! Great idea I am going to implement. Nothing like running an engine for 2-3 seconds with out op each oil change. For the duration of 30 oil changes that's at least a full minute that engine has ran without oil pressure at 90,000 miles providing 3k lofs. Think about it.
                              Tim
                              '97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
                              '03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
                              '95 SVT Aspire B3T, Green Mica, 75k miles - DD
                              '01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
                              '89 Suzuki FA50 Bright Red - Lake Transportation
                              Cardomain.com/id/aspiresvt
                              Previous Vehicles
                              '92 Festiva L "Sport" Green Mica
                              '92 Festiva GL Blue Pearl
                              '92 Capri XR2 Performance Red
                              • I fill the filters with oil but do not worry about the oil pressure thing, Rings or a head gasket will get your engine first. Good idea for sbc, sbf and such where a bearing might be what gets you.
