My n/a super b3 build
  • Re: My n/a super b3 build
    Lol yeah gonna do 15 minutes @ 2000rpm the change oil filter only then do 500 miles of nothing above 4500 rpm and easy driving then change oil and do normal driving for 3000 then run amsoil
    Sent from my LG-LS970 using Tapatalk 2
    • Sounds like a solid plan.
      • Diggin' the black and orange theme!
        -Rafe-
        Things I have for sale.
        Random Festiva Parts
        • Originally posted by drumnerd33 View Post
          Below 4500 I hope :whip2:
          • once im past the 500 mark matt said i could drive it normal.....so my normal driving is like 6000 rpm..:evil2:
            • My n/a super b3 build
              That engine bay looks awesome except for the messy wires along the firewall and drivers side strut tower
              Good luck with the start-up!
                Yeah I have been tryin to organize the wires as best as I can the ones on the firewall is for the fuel pump and it's not done yet I needed a fuse holder for it that's why it's still messy... The drivers side is kinda hard with all the stock wiring
                  Well got her started up today... Not too many problems had an oil leak on the oil pump where there is a block off plug kinda behind the alternator, had to pull it out and put teflon tape on it, not sure why it wasn't sealed properly from the factory but oh well. This thing is loud... It sounds almost exactly like ken blocks fiesta on the gymkana videos. I took video but have to edit it down and load it to YouTube so I will try and have it posted tomorrow
                  • NO! Do it now!
                      Lol I'm tired and in bed
                      • Thats fine. Just messin. Cant wait to see the vid!
                        • What oil pressure does it run at start up and at a hot idle? Did you use a new oil pump? What brand?
                          • cant remember oil pump brand off hand, ill have to look at the box, i got it from matt so yes brand new. first start it was at 70lbs then hot was like just above 50 and hot idle was 21 or so
                            • Woo! Can't wait for the vid!
                              -85' Nissan Sentra 5 spd.
                                Sounds about right. I put a new Beck-Arnley on my B6, but it has a leak between the gear cover and housing. I suspected it had a leak, but I didnt know how bad, so I installed it anyway. Its just sitting in my garage for now, but as soon as the weather warms up, I'll change change the pump out.
