The Turbo Snail !
  • The Turbo Snail !
    So if Sketch is going to make a build thread, i supopose i should too !
    Haha, So i have a 1988 Mazda 323 GT , Traded Sketch for the "black box"
    Basic Info:
    Mileage: 203,xxx
    Compression test : 150-150-150-150
    Vacuum @ Idle : 20" Hg
    So the compression is on the lower end of the factory specs, but i also used MotorVac & Seafoam on it to clean as much carbon out as possible. She smokes a little on startup and untill all the seals warm up, making the assumption that its going to need valve seals or a turbo
    Work Performed so Far:
    New MooG Endlinks front & Rear
    KYB Gr2 Silvers in Back
    KYB Gr2 Blacks in Front
    New Front Brake Pads
    Oil Change
    Trans Fluid Change
    Lots of Bulbs (exterior)
    Wipers
    New Cluster Bulbs
    Correct Leaking Sunroof
    Planned MODS :
    - Heated Seats
    - EVO 8/9 Master Brake Cyl & Reservoir
    - SS Brake Lines
    - X Drilled and Slotted Rotors
    - Carbon Kevlar Brake Pads
    - Fog Lights
    - HID Conversion
    - Relocate Battery
    - Front and Rear Strut Braces
    - Poly Bushing Kit
    - Vj11? turbo
    Ill put some pics up later tonight when i move them to my photoucket!
    Check out my HID Conversion in progress!
    Links To Pics
      nice ride!
        seems like a nice project car, good luck with the build
          Haha. Nice. Without a doubt the turbo snail decal was the 2nd to best thing to this car while I had it. 1st was it saying Mazda Familia on it and people in Kias having no idea what it was picking on it on the 4 lane. Happy times.
          Enjoy! I'll be watching.
            Updates?
              3 years later. lol
              How's this thing going? Anybody know anything?
              EDIT: Found his Photobucket. Don't see much of anything happened unless he stopped getting pics.
