Update! Update!
my first bp swap began:D
Sorry for the lack of updates no progress made been in builders block and been real busy but hopefully more progress to be made tomorrow evening.
stuff left
-littleis more grinding on block for cv clearance
-install the aftermarket escort ecu
-the 2 wires to ecu
-reinstall engine wire and fire
most of the difficult stuff is done i do believe but i can be wrong hopefully it'll fall together within the week is i dont have anything come up that'll pry me away from it89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
sorry for the threadjackbatman but how is this possible?Originally posted by Team Lightning View PostIf you can get a set of ratchet wrenches from Autozone for about 25.00 or so, you can unbolt the fuse panel and get to the bolts. It took me about 30 minutes of actual work time to swap the ECU in mine. It's a 10mm bolt. One is easy to get, the other one is the reason for the ratchet wrenches.
Oops, I thought you were talking about changing the ecu. You can hook up the 2 wires without pulling the dash.
Is there a thread/or explanation for this?
HEARD. HER FIRE UP TODAY !!!!!! Woooooooooooooo lol proud proud day for me first successful Bp swap am I the youngest to do Bo swap solo???89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
Congrats, now all we need are pics and video
Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Done a little looking into motor today has aftermarket cams,port and valve work headmen header bigger injectors and aftermarket ecu it sound bad lol89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
