FWIW, I made up a 'long trip' fuel map for the Megasquirt in my '95 BMW 318ti (now you know where my nickname came from). I set the cruise realm AFR target to 15.2 and had no trouble whatsoever with heat, backfiring, detonation, etc. Changing from 14.7 to 15.2 AFR targets, along with some other changes such as deceleration fuel cutoff, effectively netted me about an 10% improvement in MPG on the highway - went from about 400 to 440 miles per tank.
Narrow-Band O2 sensor response curve:
I run an Innovate LC-1 Wide-Band on the BMW, but for the narrow-band sensor, it looks to me that you'd want to shoot for about 0.1-0.2V range for a (barely) lean burn.
Also, if you use a volt meter (or even an O2 gauge), make sure that the voltage displayed is the same in the car as it is at the sensor itself... There is a lot of wire between the O2 sensor and the dash, and cheap voltmeters are notoriously inacurrate at very low voltages like these. To bring the O2 voltage into the car, you probably want to use a shielded cable (TV coax is probably fine) with the shield grounded at both ends.
Cheers
Cheers
