After a quick spin of the die grinder to get the polishing done on the exhaust manifold, I headed off to the DIY sandblasting/cleaning center for the aforementioned aqueous parts cleaner. Everything came out looking really great, fortunately... both the cast iron ones as well as the aluminum ones. Pictures to come shortly, I promise. While I was in the neighbourhood, I picked up a fancy vapor respirator because the fumes from all of this work with WD40 and associated chemicals has started to cause me some nasty headaches. Safety first!
With everything looking essentially brand new and all cleaned out, it was time to start up on the re-assembly process. I picked up some premium valve grinding compound and a cheap hand lapping tool with the suction cups on the end of it, and really struggled to get them done efficiently and quickly with that layout. I tried all of the tricks I was reading about in books and online from oiling the stem to reduce resistance to using alcohol and water to get the suction cup to stick to no avail. After trying five unique methods to get these darned valves lapped, I finally came up with an effective and low-cost solution. How-to to come shortly!
