Awsome!
Icetiva 3 race car build
It starts Jan 24 this year. It takes a while into the winter to build enough ice, so mid to late Jan is when we hope to start. Most racing is done in February.What is your race season? I thought it would be now.Thricetiva replaced Icetiva as the new ride
Icetiva-3-race-car-build
Yes both work, but they use different pressure plates. The Miata is certainly lighterOriginally posted by 94mx5 View PostI noticed your post with the B6T clutch/flywheel and the Miata B6 clutch/flywheel side by side. It appears either works so long as you utilize the matching clutch set, right?Thricetiva replaced Icetiva as the new ride
So did you end up finding what went wrong with the engine you paid to have rebuilt? The engine you had in last saterday was a different block that you quickly rebuilt after that right? From the way you easily won the race it looks like it worked quite well
was it running better or with more power than you had last year when you got second in rubber class? Watching you guys race makes me really want to try it but i havent yet been able to justify in my mind building a race car that i can only drive and race 6 days a year... :/ i started looking at the rules for summer racing at castrol and it looked pretty iffy as to whether they would let an ice racing car there. To replace your broken rear axle-do you have a good one on one of your parts cars? If not im sure youll find one at a wrecker before january but if not let me know. I have 2 parts cars and one of them probably has a rear axle in decent shape.*
Ok, I'll try one at a time. First, thanks for coming out to watch Ryan, it was great to meet you at the track (well, the rapidly melting lake).
The engine was another Miata block I refreshed myself, with bearings and rings, but no head work, and the head was scuzzy, so it can do better. It was making 10 psi of boost. I broke it in on a Mustang dyno, and measured 140 hp at the wheels, with corrections for Detroit standard conditions, that's 150, and the standard 1.1 conversion to DynoJet or other dynos makes it over 160 HP at the wheels. It felt like similar power to the last years, just different competition in stud versus rubber class.
The pro built engine made more I believe, as it had the head cleaned up, and made 12 psi of boost. (Boost controller is disabled, so it rises to whatever the wastegate wants to go to based on flow.)
The builder took it apart and found no build error, but two damaged bearings, and say "something went through it". I have heard that before from race engine builders whose engines failed right away. It translates to "not our fault, go pound sand" in my past experience.
My spare axle is also damaged, cracked and bent, so it would just make this a roller chassis. If you have an interest in selling a rear axle I would be delighted to pick it up. pm me on that, please.
The NASCC has a class for ice racers in the road racing category, we call it IT-J. It is not a standard WCMA class, it is a Club class, but it allows a lot of different cars to run (chump and Lemons cars included), so keep on thinking about it! Just be careful of how addictive this is.Thricetiva replaced Icetiva as the new ride
Ok, so you should ask him what he left in the block that went through it... :p no reason for a proper fresh rebuild to destroy bearings right away unless the break in was done at 7,000rpm... Are you going to push the re-builder more and hope he re-does it or at least give you a new re-build kit for free so you can do it yourself or you thinking of taking that head and putting it on the block you rebuilt?Originally posted by Icedawg View PostOk, I'll try one at a time. First, thanks for coming out to watch Ryan, it was great to meet you at the track (well, the rapidly melting lake).
With the axle i would prefer to keep mine. I have sold or given away only a couple festiva parts that i thought i would never need and then ended up needing all of them after... I may actually need one of them but i wont know till summer. So if by fall you haven't found one let me know and ill take a look at what i have. In theory i have 2, but i have no idea what shape they are in and they are 1 1/2hrs away from my place and i dont go there often.
Ok, i will look into the IT-J class, thanks. I realize its addictive, i only watched 6 races and now i want to build a race car
