My BP swap!
  • Here we go again...
    2003 Kia Rio 5 spd transmission
    2000-2001 Kia Rio axles
    The passenger side axle was missing a circlip so I cannabalized a klde circlip.
    1993 Festiva L "Wendy" BP n' stuff
    2013 Mazdaspeed 3 "The Kraken" -Stock.
    Dave Forget
    • BP clutch and flywheel with 20k kms on the clutch
      Automatic 93' 323 with the 1.8 sohc's speedo gear slid right in where the speed sensor was.
      Dave Forget
      • Redid my pass motor mount
        Dave Forget
        • Good use of lug nuts
          -Greg
          Redneck Engineer
          FOTY - '09
          • Originally posted by defprun View Post
            Here we go again...
            So you used both passenger and driver side cv shafts?
            • Identical in length (no intermediate shaft) and girth to aspire axles, except for the knuckles (bigger) and spline count (for it to work with the transmission).
              Dave Forget
              • Originally posted by eurotiva View Post
                I have some chrome ones i can use lol
                Dave Forget
                • Here's my replacement for the stock fusible links.
                  I dont have any pics of my assembling it due to time constraints but Ill awnser any questions people have.
                  The unit itself is a "power distribution block". You can get these from stores that sell audio equipment for cars or audio equipment in general but this is meant to be an underhood unit. My friend ran one in his B16 Honda Crx for two years without issue.
                  Im using 6 gauge amp wire, seems about as big as you can go to fit into the unit so thats what I used to come off the positive cable from the battery.
                  Strip the wires, I used four 4 gauge eyelet connectors for batteries, amps, they look like this:
                  I crimped two of the wires into one connector and crimped the one I was using for the 80 amp fuse (80 amp for BP alt) on its own, cut and stripped the positive wire so the starter has its own connector, and bolted all the eyelets together with a 10mm bolt.
                  The wires that these fuses feed I just stripped and clamped them into the unit.
                  Dave Forget
                  • Well poop...theres pics on fordfestiva's facebook page...im going to have to use a page to upload pix i guess...msg me on facebook, im David Forget.
                    Dave Forget
