Hey folks! I introduced myself two weeks ago when I knew I would be getting a Festiva soon but as of yesterday I became a first time Festiva owner. After getting things done at the court house the previous owner and I jacked it up to bleed the brakes as seen below:
The brake seemed like they had a lot of air in the lines and it took a random number of pumps to bring the Festy to a stop. The bleed helped for about twenty minutes then it was back to its old ways. I suspect the master cylinder because there were no viable leaks. I already ordered one of of Rockauto. Thoughts?
Then we removed the custom roof rack the previous owner had built (because drag) and took it to its new home.
I installed a new dome light from a Mazda B220 truck with some fresh LED's. The door function doesn't work for some reason. Neither does the horn. Could be a fuse? Next I replaced the taillight gaskets using the mouse pad trick. The old ones crumbled in my hand as I removed them. I also replaced some burnt out bulbs in the back while I was at it.
I washed/vacuumed the Festiva to the best of my ability but that oxidized paint is hard to make look good. I'm going to borrow a buffing wheel and some industrial strength compound from one of the detail guys at work. He gave me a little preview on the hood:
Should shine up like glass!
Problems I need some advice on:
Upcoming projects:
This forum has already been more than helpful. I look forward to chatting with you all. Thanks.
- Brakes. After bleed squishy pedal continues, take several pumps to stop. Going to replace master cylinder.
- Dome light won't come in door switch
- Horn doesn't work
- Body/wheel/suspension popping sound when coasting
Upcoming projects:
- Adding Hella 500 rally lights
- Oil/filter change
- Plastidip bumpers/trim/wheels
- Escort/MX-3/Aspire seat swap
- Finding/fixing exhaust leak.
