I have decided to resurrect My 1993 GL Festiva from a parts car.
Currently named Silver Streak, I plan on painting it silver and black.
In April, I plan on driving it down to North Carolina early to have a B6 put in during the spring NCStiva meet. First I have to get it road worthy to do that.
The photos below are from most recent to last spring.
These 2 photos I was checking & bleeding the brakes. I test drove it afterwards and I still had to pump the brakes to get it to stop. I believe it needs a master cylinder. I also think it needs a left front wheel bearing also. I will go to the JY and get an Aspire master cylinder when I get a chance. I read on here you can use an Aspire master cylinder. It also has a vibration in the steering wheel which could be bad tires. They are old. There is only a few rust spots that need attention, One little hole is on the frame near the rear axel mount. I will have my welder friend fix that and the hole under the passenger door, eventually. It's not serious.
This photo I had just put the wheels and fender on & it's sitting on all 4 wheels again after a few months on blocks.
This photo I was replacing the brain in the car. A battery had exploded in the car shortly after I purchased it & caused some damaged to the hood, radiator, and brain.
These photos were taken during the time I was using it as a parts car When the battery exploded in the engine bay, I decided to use it as a parts car then.
I will post more pics as I work on it. It will take some time as I am limited with funds.
Any advice is welcome!!
