That looks amazing
90LX Build
Went to Kentucky to get this B8 with 41,000 miles. From what I've seen, the engine is in pretty great shape. Fingers crossed to have it in by the 4th of July.
The guy had 5-9 more engines that would work in a swap, depending. PM me if you're interested as to where it's located.
Nice! What are you going to use for fuel injection?Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Did the B8 swap and it is finally running well. Only changes I needed to tweak were the following: needed to use protégé disty and needed new fuel injectors.
I know, I know....it needs wires tucked.
Factory A/C. Just kept it attached to the car and worked it around the engine during install. I can say that it WAS a headache, but better than a conversion and a recharge.
Relocating the battery may not be worth mentioning, but I cut the old battery tray in half and made some mounts to hold on the passenger side.
Wanted to update the build with the hitch I attached. I got the idea from William, but Tom has a write-up on here somewhere. It's not finished, but here is what I have done.
Then I peeled it down
I also welded in some grade 8's because I felt like it. A hole needs to be drilled out to accommodate the 4th stud. I will update this when completed.
uploadfromtaptalk1447558819983.jpgLast edited by DrFestiva88; 11-14-2015, 10:41 PM.
FYI: To clean plasti dip i use purple power from the dollar store. Spray it on hose it off. The purple power will eat the dip if it sits on it longer then 20-30 seconds so spray on hose off.
You will see the brake dust almost jump off. I have white dipped rims on my bike. PP is the only thing i use to clean them now.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Hope to get to see your car at the Hermann meet!
