Well it's been down for two weeks, it appears the motor had a weak head gasket. Not a visible thing till you drive it and see what happens as it heat cycles etc, pulled the head off and checked the head, on intake valve was holding 24" vacuum and none of the exhaust or intake valves were holding even close to that, lesson learned when I buy a junkyard motor go past the valve cover and check head and block,
Well took the head and had machined and a 3 angle valve job simple but effective, head went back on last night and she lives WAY stronger holding boost and compression now! It's my fault didn't check the Head Gasket and I should have.. Oh well she's back!
Next item of business is suspension and I'm working on that now....
Mike
Bandit -89 festiva B6t
Mike
