This is my first Festiva!
A little background on the purchase can be found here:Just bought my first Festiva
So I'm starting this thread to document the condition I recieved the car in and to keep track of all the changes I make.
THE BAD
The car currently has a bunch of little problems. First, it pulls to the left on acceleration/right on decel. I read up on it and have decided to swap in new moog sway bar to LCA bushings. They should arrive tomorrow so I will be updating this when the time comes.
Anything from the ground up to 10 inches is super rusted. All my brake lines/body panels/hubs/frame. The PO covered the bottom of the body with truck bed liner but didn't actually remove the rust first, just sprayed over it. Not much I can do about that.
The PO replaced the front pads and rotors, and the drive shafts.
The rear brake assembly has been removed from the hub. All rear brake lines have been snipped and the parking brake is therefore not functional. I am considering the aspire swap to fix this.
The parking brake lever does not stay down, so the light is always on in the dash.
The dome light doesnt work. I still need to trouble shoot that one.
The seats are torn up, will be swapping those eventually.
The windows love to come off the tracks.
The shifter is super loose, I will be doing those bushings sometime, maybe even a short shifter.
Owner before the PO was a heavy smoker, there are a couple burns on the carpet. The headliner and seatbelt rail covers are super tan from smoke.
PO covered the interior rear panels in bedliner (WHY??)'
PO put in broken fog lights, used wayy to much wire. THe switch was duct taped to the steering column and he spliced power from the cigarette lighter.
Front windshield is craked
Exhaust is held on with garbage flex-pipe
Tailgate latch is broken, must be opened from the inside by fiddling with the mechanism
THE GOOD
The gauges all work
The headlights/tailights/markers all work
The dash is not cracked
The carpets are in good shape
Came with spare tire & jack & wrench
The engine and trans are working perfectly
The PO just put on a brand new tint job (You can see where his priorities were)
Wipers work
Has a long Cherry Bomb glasspack muffler
THE BUILD & FIXES
So the first thing I had to do was put in a radio. Some of you may think that rear brakes or suspension is important, but the exhaust drone would have driven me insane. I got a nice pioneer head unit with bluetooth and kicker 4" in the stock front location. I skipped the rear speakers. I then removed the rear seats and put 2 12" kicker subs and amp in the back. The sub box kept sliding around so I made up some brackets to hold it down. These go into the holes where the rear seatbelts were mounted (See Pics).
So far this is all I done. If there are any parts of the car you all would like information/pics on before I change them, let me know!
20150411_121605.jpg20150411_121819.jpg20150416_141411.jpg20150416_141525.jpg20150416_141433.jpg20150416_141500.jpg20150416_141442.jpg
THE BAD
THE GOOD
The gauges all work
Wipers work
THE BUILD & FIXES
