Nice! Did you get your drums drilled yet?
1st b6t/festiva build (slow)
Not yet. Shop is busy. I hope they get to it soon tho. I will put them on the grey car for now once drilled. They will go over to the black car once its ready to run.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Drums are finally done! Night shift did it and i let them wait for the new guy to do them. They had another guy walk him through it tho. I didn't have to do it myself so thats nice. The holes should be dead on! They used a dial indicator on the spindle to get the drums located dead center then used the digital readout to hit 100mm.
I am picking up the new festy after work. Once home i will rebuild the rear end on the grey car. Gonna add some washers under the spindles for now to get some NEG camber until the switch over to the new car. I will then use some camber plates to do it right. Also next week i will have it in the shop for an alignment.
I have to finish up a car thats in the garage now. The wifes car needs to be finished and then i can jump into the festiva motot transplant full tilt. I hope i can start on the festy in 2-3 weeks at the latest.Last edited by Advancedynamix; 03-11-2016, 10:20 PM.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Great news! The rear spindles shimming is kind of tedious. Just keep messing with it until you get zero toe with the camber you want.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Will do thanks! I hope to get on this tomorrow. Got the new car home today. You guys know her as Britstiva 1.01990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Which ones do you mean? the red ones or my new enkei's?Originally posted by errjam View PostThose wheels look awesome
ill have all 4 enkei's on this weekend finally!!!1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
I finally have all 4 enkei's on!!! Will post a picture up soon. The car looks great like this. The enkei match the car 100% perfect.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Front caliper just locked up on me. Good thing i was 1/2 mile from my drive. I have 2 new calipers on order. Will have them on tomorrow. Front end alignment got pushed back to Thursday. 53$ each means its about the most expensive thing i have on my car now!. I guess the good side is that now i will have all new brakes front and rear (soft hose to pads in front and everything but springs in the rear).
So ready for more power now! This slow build is killing me...1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
That is true. It would be nice if the new calipers help cut down on some of the vibs i get. The only thing left is the front end alignment!Originally posted by Green Bean View PostBetter a slow build sometimes than a fast one where mistakes can cost ya.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
The 03 kia rio brake calipers were 52.9$9 each with a 40$ core charge! So that wasn't fun. Now my front swap is 100% new aside from the knuckles. I need to bleed the system a bit more tho. Will need to bleed the spliter valve and shes done.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
sometimes the hose collapse and causes the caliper not to release....Originally posted by mikemounlio View PostThe 03 kia rio brake calipers were 52.9$9 each with a 40$ core charge! So that wasn't fun. Now my front swap is 100% new aside from the knuckles. I need to bleed the system a bit more tho. Will need to bleed the spliter valve and shes done.
The hoses are brand new! I hope they didn't give out already. They are less then a month or two old.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
