Well, I did a bunch of work on the car and should update my build thread since thats what its for. I wanted to start taking the kids around in it so i needed a quieter exhaust. Also wanted to change the transmission at the same time and it all snowballed into more work. Way more work. I did it at where I work which is an hour drive each way from home and tried to do it on a long weekend. Ended up taking almost a week and over 50 hours since i only had 2 days of the long weekend free... :/
- spent a long time washing the engine bay and under the car. I bought terrible degreaser. Never buy 'gunk' degreaser.
-remove exhaust, broke bolts on catalytic converter, had to find a new used one and spent 1/2 an hour blowing tons of smoke/dust out of it. Installed a different 'downpipe', different cat, old 2 inch pipe i found and welded my stock muffler back on to that. Very quiet now, old exhaust was rotted out and i had no resonator or muffler anymore but I liked the sound.
- installed lap seat belts from an astro van in the back for the carseats. had to modify the brackets a bit.
- remove transmission, Broke off a captive nut on the crossmember and had to remove the bumper and cut a hole in the rad support to get to it. The other 3 took a very long time with lots of penetrating fluid and heat.
-removed flywheel
-took off valve cover, rocker arms and camshaft. cleaned them in varsol and other solvents. Cleaned out the top of the motor. Forgot to measure cam lobes. Was going to now and after my trip to see how much they wore.
-installed new camshaft seal
-new seal on the distributor, old one basically fell off...
-new valve cover gasket
-timing belt area was covered in oil. cleaned all that out and cleaned the belt.
-replaced front crank seal, old one had almost fallen out! I just touched it with my pick and it fell out.
-cleaned up new timing covers and put them on.
-cleaned engine with brake cleaner as best I could since the degreaser sucked.
-removed the oil pan and cleaned it. My magnets had caught quite a bit of metal. forgot to measure crank end play. Installed new gasket.
-replaced rear main crank seal.
-installed a proper washer fluid bottle and tube and glued them together. Before I always had problems with dirt getting in them and killing the motors.
-Installed a mazda thermostat, should have done that years ago... :/
-installed a new heater hose, new bypass hose and replaced the fan sensor in the thermostat housing with a sending unit for a gauge. Fan has been on a switch a long time anyway.
-my flywheel was heated up bad from slipping on that oil so i took one off a parts engine, sanded it and used it. Installed a new pilot bearing.
-Installed my new autocom clutch kit.
-spend 1 1/2hrs cleaning a new transmission, then spent 2 hours trying to remove the cv shafts and couldnt. Had to go pick up more brake cleaner and clean a different transmission. Had to put my old sensors on it since the wires were broken.
- installed new output shaft seals and motor mounts, installed transmission.
-started putting starter in but whoever had it before had crossthreaded one starter bolt hole. tapped the hole. installed starter. couldnt find wire. starter wire pinched between engine and transmission. Had to take starter back out and loosen all trans bolts a long ways to get it out. reinstalled trans bolts and starter...
-new o-ring on speedo cable
-installed a second catch can
-cleaned all the oil out of my intake tubing
-bled coolant then seafoamed probably 1/4 of the oil out of the intake manifold... made a huge difference though!
-removed foglights, wired coolant bottle, played with my clutch cable, seems to be messed up...
- i overtightened a rear wheel bearing a while back. re-greased it and installed it loosish. New drums and bearings coming soon.
-drove it around. I was sure at first that it was slower than before I did all this. But I drove home with an engine in the back, changed my transmission fluid, and then drove 500km with the wife, 2 kids and tons of gear and now i cant be sure of how it used to be. I know louder makes it feel faster but I kinda have this feeling its slower. Going to check my ignition timing. Also weird things happen when I put the car in gear, but ill ask about that later if I cant figure it out. Its about 700km post operation and there seems to be no leaks! Changing my engine oil tomorrow or the day after to get that engine assembly lube out.
-removed flywheel
