I'm from Australia and here is my little avocado sh*tbox.
I picked it up for $200 off the side of the road... Bit of a bargain considering it's only done 175,000kms.
It's a little beat up on the outside but the driveline is in great condition. Only things I had to replace to get it registered and on the road was a LH driveshaft and an O-ring on the distributor.
My plan for the car is to turn it into a reliable daily and maybe go to the occasional hill climb or track day.
Here's a rough build plan (subject to change or failures):
Suspension/Brakes/Wheels:
-Coilovers using Golf parts as suggested on this forum
-Slotted Rotors (haven't researched this yet)
-Bendix Pads (already installed)
-Some 14 or 15 inch old school jap wheels with a bit less offset for better track width
Engine/Driveline
-NA BP engine from Ford Laser, Protege/323 or Kia Sehpia + Timing belt, waterpump & full gasket/seal kit
-Complete engine harness + ECU from donor vehicle
-6mm Steel plate for fabbing mounts
-F-series cable-clutch tranny from B5 Aspire/Festiva, 80's 323 or 80's Ford Laser
-Flywheel + Starter to suit
-New HD clutch
-Driveshafts to suit... I think I need non-turbo capri or auto aspire axles.
-Kia rio radiator hoses
-Maybe a bigger radiator... auto aspire has a thicker core, might be an option.
-2.5 inch exhaust with suitable muffler
-Don't know if this is necessary but perhaps and upgraded fuel pump
Interior/Aesthetics
-Weight reduction... goodbye rear seats, belts, spare tyre, tools etc. (done)
-Better seats.. stock ones are terrible. Probably try to fit some OEM seats from a honda, golf gti or WRX etc...
-Tacho
-Some better speakers
-Pull some dints out of the doors
-Repaint some faded plastics
-Better headlight globes... this car has the worst stock headlights ever.
That's basically it.
I'll probably start with the things that'll make this car a bit more bearable to drive on a daily basis... seats, headlights, suspension, wheels and tyres. If I can get this mouldy green egg to look half decent I'll be less likely to give up haha
If anyone in Australia can help me out with cheap parts let me know
Engine/Driveline
-New HD clutch
Interior/Aesthetics
-Tacho
